Yelp Deletion Guide
How to Mass Delete Your Yelp Reviews and Comments
5 min read
Negative Yelp reviews might have felt cathartic at the time, but they can come back to haunt you. Whether you’re protecting your privacy, managing your online presence, or simply wiping the slate clean, Redact makes it fast and easy to bulk delete your Yelp content.
Why Use Redact for Yelp?
Redact is the fastest, easiest way to take control of your Yelp presence. Instead of digging through reviews one at a time, Redact allows you to:
  • Delete multiple reviews or comments in a single click
  • Remove outdated or embarrassing content
  • Protect your privacy and reputation
  • Manage your Yelp presence on your own terms
If you want to fully erase your Yelp activity or just clean up your account, Redact is the tool that gets it done quickly and efficiently.
Please note: mass deleting your Yelp Reviews and Comments with Redact requires a Redact Ultimate subscription. You can try Redact for free on Twitter/X, Discord, Reddit, and Facebook!
2. Filter by Date Range
If you want to delete your Yelp reviews from a specific time period, Redact.dev supports date ranger filters.
This means you can easily wipe all your activity on Yelp from individual days, entire months, or full years to narrow down the exact timeframe of the content you want to remove.
Use the date filter to:
  • Set a Start Date to delete anything created after that day
  • Set an End Date to delete anything before that day
  • Set Both to delete anything between the two dates
You can use the presets, or click the calendar icon to choose by day, month, or year. Click the red Reset text to clear your filter.
Delete Yelp activity by date range Redaction can be specified by Start Date (Only delete after this date) or End Date (Only delete before this date), pressing the calendar icon, you go straight to month selection by pressing the month ie April, pressing the title again Pick Month in 2021 will navigate to year selection. Clicking the Reset red text will delete all the date value for that field.
3. Filter Yelp Bulk Deletion By Review Text & Genre
With Redact, you can bulk delete Yelp reviews you’ve left based on specific keywords or business “genres” you’ve reviewed – easily delete every Pizza shop review you’ve left, or every review with bad words.
4. Filter Yelp Bulk Deletion By Location, Business Name, or Price Rating
Need more precision? Redact.dev’s advanced filters let you batch-remove Yelp reviews by city, specific business name, or even Yelp’s price-rating tiers ($ to $$$$).
Whether you want to clean out reviews you left while traveling, everything you posted about cheap eats, or all the 13 reviews you’ve left for various McDonalds locations – Redact has you covered. Select your target criteria, preview the matches, and delete in bulk.
5. Bulk Delete Yelp Reviews Based on Star Rating
Redact.dev lets you instantly bulk delete Yelp reviews by star rating, so you can wipe out the noise and keep the praise. Just pick the rating range – 1-star flame-outs, 5-star praise and anything in between. Our tool scrubs them in a single click.
No more hunting line-by-line through your review history; the star-filter does the heavy lifting, saving hours and protecting your credibility. Clean, fast, and fully private – exactly what you need to keep your Yelp footprint five-star fresh.
Start Deleting
Redact offers three deletion modes:
  • Preview Mode: Review content before deletion to avoid mistakes
  • Select and Delete: Manually choose which files to remove
  • Deletion Mode: Instantly delete all selected Yelp reviews
  • Schedule Deletion: This lets you automate ongoing Yelp review deletion, so your reviews and comments on Yelp are deleted after a set period of time.
If you’re looking to wipe your Yelp account completely, skip the filters and go straight to Deletion Mode. This will remove all selected data permanently.
Final Thoughts
Whether you’re dealing with past posts that no longer reflect you or you’re looking to fully reset your Yelp account, Redact gives you the control you need.
Redact also supports dozens of other major social and productivity platforms. You can try it free for deletions on Discord, Twitter, and Facebook, and Reddit.
