Disqus Deletion Guide
Mass Delete Your Disqus Comments with Redact
4 min read
Disqus comments can span years across countless sites – often forgotten, but still searchable. These old remarks may include outdated opinions, personal details, or content taken out of context. If you’ve ever wanted to delete your Disqus comments in bulk, you’ve probably realized Disqus doesn’t offer a way to do this. Deleting all your Disqus comments manually is a time-consuming, tedious process;
  1. Navigate to your profile, then your comment history.
  2. Right click “View in Discussion” to open individual comments in a new tab.
  3. When the page loads, click the drop-down, then click Delete to remove the comment
  4. Repeat this process for all comments you want to delete.
This process will likely take hours or longer depending on your use of Disqus. Whether you’re looking to clean up old comments, want to protect your privacy, Redact.dev makes it easy to bulk delete your Disqus activity in one go.
Why Use Redact for Disqus?
Redact helps you regain control by letting you search and delete comments based on date or specific keywords. Whether you want to clean up your public presence, protect your privacy, or simply reduce your digital footprint, Redact offers an efficient, secure, and customizable way to manage your Disqus history.
Please note – mass deleting your Disqus using Redact requires a Redact Premium subscription. You can try Redact for free on Twitter/X, Discord, Reddit and Facebook!
2. Connect Your Disqus Account
Follow the secure authentication steps to connect your account to Redact.dev. This works the same was as logging in to Disqus through a browser – we don’t store or see your account credentials at all; all sensitive info is only processed directly by you, and by Disqus.
In the Redact.dev app, select Disqus from the list of supported platforms.
In Redact.dev, select Disqus from the list of supported platforms.
3. Delete by Date Range
Redact lets you select specific types of content in your Disqus account:
Choose a custom timeframe to remove your comments.
  • Set a Start Date to delete Disqus content after the set date.
  • Set an End Date to bulk remove Disqus content from before a set date.
  • Use the calendar tool to easily select the month or year for your Disqus mass deletion.
  • Click the Reset button to clear your filters
These settings are perfect for deleting posts tied to specific events or outdated opinions you’ve shared on Disqus.
Mass deletion of emails can be specified by Start Date (only delete emails after this date) or End Date (only delete emails before this date). You can select by month by clicking the month label, and by year by clicking the year label. Clicking the Reset red text will reset the date value for that field.
4. Delete by Disqus Title Keyword or Phrase
Redact lets you target specific Disqus content by entering a word or phrase that appears in your content’s title.
Just enter the phrase you’d like Redact to search for, and we’ll find any of your content where that phrase or keyword is used in the title. This is great for finding and removing outdated opinions or sensitive discussions.
5. Wipe Your Entire Disqus History
If you want a clean slate, skip the filters, select Deletion Mode, and click Start Deleting. This will permanently remove all your comments. Use this only if you’re sure – there’s no undo.
We recommend running “preview” mode before bulk deleting – this way, you can quickly review your old Disqus content in one place before deciding if there’s anything you want to keep.
If you’re ready to mass delete, or start automating deletion of your Disqus content – you can get started in a few minutes; just get Redact Premium from as little as $7.99 a month. If you’d like to try Redact out before subscribing, you can start cleaning up your content and messages on Facebook, Reddit, Twitter, and Discord for free! Just download Redact and get started.
