Bumble Deletion Guide
How to Delete All Your Bumble Matches and Chats
4 min read
Dating apps like Bumble can accumulate a lot of clutter over time. From old matches and stale conversations to entire histories you’d rather forget, Redact gives you the tools to clean it all up in a few clicks.
If you’re ready to reset your Bumble experience or simply clear out old content, this guide shows you exactly how to do it with Redact.
Please note: mass deleting your Bumble Matches and Chats with Redact requires a Redact Premium subscription. You can try Redact for free on Twitter/X, Discord, Reddit, and Facebook!
Why Use Redact for Bumble?
Redact is the fastest and most efficient way to manage your dating app presence. Rather than unmatching users one by one, Redact lets you:
  • Mass delete matches and conversations
  • Target content by gender or match type
  • Start fresh with a clean slate
  • You found a boyfriend or girlfriend! (Good job!)
It’s ideal for anyone wanting to reduce digital baggage or maintain better control over their online dating footprint.
2. Connect Your Bumble Account
Once you launch Redact.dev and log in, choose Bumble from the list of supported platforms.
You’ll be prompted to log in through Bumble. Your login details are never seen or stored by Redact. They’re sent directly from your device to Bumble, just like a saved login in your browser. Everything stays local to your device.
3. Choose What to Delete
Redact gives you options to delete specific types of Bumble content:
  • Matches with a conversation
  • Matches in your match queue
  • Matches in your Beeline
You can select one, two, or all three to remove from Bumble at once.
4. Filter by Gender (Optional)
Want to target match deletions by gender? Redact lets you choose between:
  • Male
  • Female
  • Non-binary
This helps fine-tune your removal preferences, and remove all matches based on their specific gender.
5. Start Deleting
Redact offers multiple deletion modes for Bumble:
  • Preview Mode: Review your matches and activity before deleting to ensure accuracy
  • Select and Delete: Manually pick which matches or data to remove
  • Deletion Mode: Instantly delete all selected Bumble content in one go
  • Schedule Deletion: Automate ongoing cleanup by scheduling future Bumble data deletions
If you want to completely wipe your Bumble matches and chats, skip the filters and use Deletion Mode. This will permanently remove all selected content. We recommend starting with Preview Mode to avoid deleting anything unintentionally.
Your Bumble history might be filled with old matches, awkward conversations, or data you no longer want tied to your account. Whether you’re cleaning up your digital life or starting fresh, Redact is the fastest and easiest way to mass delete Bumble matches and activity.
Redact also supports dozens of other major social and productivity platforms. You can try it free for deletions on Discord, Twitter, and Facebook, and Reddit.
