I’ve been tryng to clean up some of my old digital footprints, specifically in Discord servers for our server of MJLauncher in Discord.
I was previously using Undiscord to batch-delete my historical messages and files from there, but the server is quite large and the script keeps failing, freezing, or missing batches. Not to mention, I read it might be a risk for Discord bans.
Before switching over and setting up Redact, I wanted to ask:
Will Redact be able to scan and completely wipe all of my messages, posts, and media attachments from a specific, busy gaming Discord server like this without errors or freezing?
How does Redact bypass the rate-limiting and freezing issues that other tools/scripts face when dealing with thousands of messages in large servers?
Wanting to make sure this is the right tool for the job before I proceed. Thanks!
(1) Yes, Redact handles busy servers and can clear your messages, posts and media attachments in a specific server. Forum posts and threads work too, and you can keep pinned messages.
You’ll need to still be a member of the server you’re deleting from. If there’s a channel your account can’t open normally, Redact won’t be able to delete from it either. For very old history, you can also load your Discord data package into Redact to catch messages that Discord’s search misses.
(2) Redact is built to respect Discord’s rate limits. When Discord tells it to slow down, it waits and then picks up where it left off, so batches don’t get skipped. On a big server those waits can be long, and the status line tells you when it’s pausing. It’s waiting, not frozen.
