Imgur Deletion Guide
How to Delete Your Imgur Post History
6 min read
Imgur has long been a place to post memes, share inside jokes with friends, or leave funny comments on viral images. But over time, your Imgur account may no longer reflect your current self. Whether it is old image posts, cringeworthy comments, or random favorites, Redact makes it easy to clean house.
Please note – mass deleting your Imgur posts requires a Redact Premium subscription. You can try Redact for free on Twitter/X, Discord, Reddit and Facebook!
Here is how you can use Redact to mass delete your Imgur posts, comments, and favorites in just a few clicks.
Why Use Redact for Imgur
  • Quickly remove outdated or embarrassing content
  • Control your public online image
  • Clean up old favorites you no longer want to be associated with
Imgur doesn’t make it easy to manage your history in bulk. Redact fills that gap with powerful deletion tools.
Download and Set Up Redact
To get started, download the Redact app from Redact.dev.
Connect Your Imgur Account
In Redact.dev, select Imgur from the list of supported platforms.
Select Imgur on the Redact app
Choose What You Want to Delete
You can delete any or all of the following:
  • Image submissions (posts)
  • Comments
  • Favorites
Simply check the boxes for the content types you want to remove so you can mass delete your Imgur submissions, bulk delete your Imgur comments or wipe all your favorites.
Our software offers you a great way to take control of your posts and comment history on Imgur. With just a few clicks, you can quickly mass delete your image submissions, remove comments in bulk, or unfavorite pictures you've previously liked. The process is simple and powerful: select the type of Imgur content you want to delete by checking the appropriate boxes on the app settings screen. Whether you need to delete a single type of content or are looking for a bulk deletion of all content, our software is equipped to handle it like a boss.
For bulk deletion Imgur submissions, you can choose to delete based on the text in the title. This lets you filter your bulk Imgur deletion with whatever level of precision you need.
You can also choose to delete your Imgur favorites and albums based off of tags that are on submissions – allowing for an even more precise mass Imgur deletion.
And if you have been a little cheeky, you can choose to delete posts that are NSFW! There’s never been an easier way to wipe all your NSFW Imgur albums and favorites.
If you want to keep your viral Imgur content and delete the rest, you can choose to delete posts based off how many comments, points, or favorites they have.
Filter by Date Range
If you only want to delete content from a certain time period:
The Redact App allows you to delete pictures and comments by specific date ranges. Deletion can be specified by start date (only delete after this date) or end date (only delete before this date). When you press the calendar icon, a calendar will appear. By default, it’ll take you to the current date, but you can easily change this. You can click the title at the top to select from a list of months, or click it twice to select from a list of nearby years. Alternatively, you could click the left and right arrows to skip around to adjacent months. When you have the correct month and year, you just click the day and you’re done. If you want to start over, just tap the reset button in red text.
Start the Deletion Process
Redact offers several deletion modes:
  • Preview Mode: See what will be deleted based on your filters
  • Deletion Mode: Delete all selected content immediately
  • Select and Delete Mode: Review and manually choose what to keep or remove
  • Schedule Deletion: this lets you schedule regular deletions based on your parameters
If you want to wipe everything from your Imgur account, skip the filters and go straight to deletion mode.
Your Imgur account says a lot about you. Whether you’re looking to protect your privacy or just declutter your digital life, Redact makes the process fast and easy.
Redact also supports a massive range of major social media and productivity platforms – like Twitter, Facebook, LinkedIn, Slack and more.
