How do I get rid of all my followers on tiktok
as the title says, this app is advertised by saying I get delete followers on tiktok. I don’t mean to unfollow people who I’m following, I am asking specifically about deleteing people who are following ME!
Just load redact and push the start button under followers tab
if you dont use the date picker it will remove all your followers. basically, it mass blocks then mass unblocks the people following you which causes the tiktok system to automatically make those people unfollow you. kind of cool because it doesnt alert the person that anything happened…stealthy!
It’s super intuitive, just load the app and play around with it you’ll get it easy
Redact does this for you. It’s under the Followers tab in the TikTok tool and it’s all or nothing: there’s no date picker or filter for followers, so ignore that part above. Under the hood it blocks and then unblocks each follower, which makes TikTok drop the follow, and nobody gets a notification. It runs in the desktop app on Windows, macOS or Linux (free to download); the follower tools are on the Premium plan. Details here: Mass Remove TikTok Followers in Bulk | Redact
