Deleting discord account without being logged in
How would one go about deleting discord but doing so without being logged in? Is this possible?
Doesn’t seem possible unless you email support. But even then, how can you prove it’s your account? Discord support isn’t going to be like “oh, you want such and such account deleted? Yeah sure, no problemo”.
Why are you unable to login to Discord?
yeah I don’tr know how this would work or why it would even be allowed by discord. Discord’s delete button is inside your account settings, so you have to be able to log in to start deletion. Discord also says deletions take 15 days to process, and Support cant make it happen faster
If youre in a region with strong privacy laws like the EU with GDPR or California with CCPA, you can send a formal ‘Right to Erasure’ or ‘Request to Delete’ notice to discords privacy email.
Platforms are legally obligated to process these even if you can’t use the standard ‘delete’ button in the app, though they will still perform a strict identity check to make sure you aren’t trying to delete someone else’s account.
do you have access to the email the account is on? you’re going to have to prove to support that you own the account, if you dont own the email the account is on, I don’t know how this would work.
This is not something easily accomplished, I’d guess. Maybe if you email Discord support directly from the email that holds your discord account, they will help you. Otherwise, no chance.
