When I block a user on discord, what happens to the old messages? Can the other person still see the old messages or does Discord unsend/remove the old conversation you had with this person?
Blocking a user on Discord prevents them from:
Sending you new Direct Messages (theyâll receive a generic error message if they try).
Sending you a friend request.
@mentioning or âpingingâ you in a server (you wonât receive a notification).
Adding reactions to your messages.
Seeing certain profile details like your âAbout Meâ section or activity status.
Blocking the person on Discord DOES NOT delete your old messages.
If you want to delete your old messages, you have to use Redact (how to remove old messages in bulk) or delete your old messages one by one using the official discord delete method.
Hope this helps!
No thatâs not how blocking works on Discord. You have to use Redact and mass delete the messages, blocking doesnât do what youâre wanting.
Unfortunately, no. Blocking someone on Discord doesnât delete the chat history. It effectively just mutes them and stops them from sending you new DMs, but they can still see all the old messages you sent in the past.
If you want the history gone, you actually have to go back and delete the messages yourself. Blocking is more of a filter for future interactions rather than a cleanup tool for old ones.
Yeah, it is super misleading.
When you block them, their messages get hidden for you behind that âBlocked Messageâ bar, so it feels like the chat is gone. But for them, nothing changes in the history. They can still scroll up and screenshot everything.
You definitely have to delete the messages first if you actually want the info gone.
blocking on discord doesnât delete anything in the convo history
Man I learned this the hard way last year. Had a falling out with someone who used to be a close friend, blocked them on Discord and Instagram and called it done. A few weeks later a mutual friend told me the blocked friend had been showing screenshots of our old DMs to other people in our group including stuff Iâd written when I was upset and not at my best. NOT GOOD.
Block is a âI donât want to interact with you anymoreâ tool. It is not a âwhat we talked about is goneâ tool. If you actually want the history wiped, you have to go in and delete it before you block, or you have to use Redact to scrub the conversation after the fact. Wish someone had told me that before I assumed blocking was a clean break. It most def is not clean.
