Hi all. Been using the Instagram DM deletion feature for a decent while with moderate success. However, a new problem has arisen where a message with register but then be marked as “deletion failed.” Has anyone else encountered this issue or found a way to solve it?
I have submitted a support ticket for this, will update you soon.
Wonderful, thank you!
Hey folks, we’re investigating this one actively and will update you all when we’ve got a fix out.
Thanks @wooly you’re such a dreamboat
