Telegram won’t connect.
I bought a Premium subscription, but Telegram won’t connect. Please help.
I submitted a support ticket for you, someone should reach out soon.
Is your email the same one you used to signup for the forum? That is the email I submitted to support, (the 744 one)
If it’s not thje same one you used when purchasing, please send them an email at support@redact.dev with the email you used to join and signup.
Otherwise, someone will be with you soon.
