Disable Instagram Map Location Sharing
Yo! You might have heard about the new instagram maps feature - instagram are saying it’s opt-in only but users claim they’ve been defaulted into the feature.
How to Turn Off Instagram Maps (2025)
There are two methods to disable the map – through your DMs, or via the in-app settings, according to Instagram user @jakegoodmanmd
Disabling Instagram maps via direct messages
  1. Open Instagram on your phone
  2. Navigate to your Direct Messages / DM inbox
  3. Tap the map icon at the top right of your inbox – if you can’t see it, maps likely hasn’t rolled out in your location yet.
  4. Tap the settings gear icon at the top-right corner of the map
  5. Under the “Who can see your location?” section, select the No one option.
  6. Tap Done or Update to confirm the change.
Disabling Instagram maps via app settings
  2. Tap the hamburger menu in the top right (≡) – usually found on your profile page.
  3. Tap “Settings and activity”
  4. Go to “Story, Live, and Location” or just search for Map
  5. Tap “Location Sharing (Instagram Map)”
  6. Select No One and tap Done.
How to disable all location sharing with Instagram
Once you’ve disabled Instagram map sharing, we recommend revoking location sharing permission in your device settings for Instagram. This way, if Instagram ship more features that expose user locations, they won’t be able to share yours automatically.
For most devices, you can do this by following the steps below
  1. Go to your on-devices settings
  2. Navigate to Instagram settings (or search)
  3. Enter the Location settings in the Instagram menu
  4. Swap it to Never
