Anyone have any first-hand reviews of privacy hawk?
Thinking about giving it a go, anyone use/used it? Was it good? Would you recommend it?
So far Privacy Hawk has found and removed a bunch of data brokers I didn’t even know were selling my info. I’ve also gotten quite a few replies from legit companies saying they’ll take care of it. A few have been a pain to deal with, but Privacy Hawk is staying on them and sending me details so I can reach out directly too. Overall I have been really happy.
Not sure I have been using it long enough to recommend it to others, but from what I have seen so far it’s super solid.
I was looking at trying this a few months back due to the insane amount of daily spam calls I get. I ultimately decided not to because I didn’t want to spend the money. Interested to see what others say, I may have to give it a second thought.
I noticed a significant reduction in spam calls and pretty fast too
I don’t know man, I didn’t see much of a change. My phone is pretty much not useable due to the obscene amount of spam I get. It may have reduced it some, I can’t even tell. I can tell you for sure it didn’t make a big enough difference to make my life any better. Not worth the money IMO.
read this reddit thread Reddit - The heart of the internet
Decent service, but something went sideways before my plan even ran out, a bunch of features disappeared. It might be tied to moving to a new phone, but if you log in with the same email, everything should restore automatically. My subscription is good through June 26, so I’ll just let it finish, but I’m not planning to renew.
I’m a current customer of Privacy Hawk, I was honestly reaching my breaking point with all the spam calls lately, but this app fixed it. Within a couple of days, the ‘unsolicited’ noise just… stopped. It’s super convenient because it works its magic in the background while you go about your day.
Check this link: Data Removal Comparison Table.xlsx - Google Sheets
There are so many better apps out there than Privacy Hawk, check that URL and don’t buy Privacy Hawk
I never heard of it till just now, looks like a cool service though
There are better options for cheaper. It’s not the worst decision you could ever make, but if you spend a littlke time researching you will likely find something that fits your needs much better than Privacy Hawk.
