[SOLVED] Is protonmail supported
Does redact.dev support deleting protonmail emails
Hey @persons not currently, protonmail doesn’t support IMAP directly which our email deletion feature currently requires.
We’re open to expanding our email deletion functionality to include more platforms (Proton included) if there’s a healthy amount of desire for it. If you know of anyone else that would use this, feel free to encourage them to like your post - this will help us prioritize your request.
ok thanks. I ended up copying and pasting a command into the console and all my emails have been deleted to give me storage space
@persons Actually there is Proton Bridge, it allows you to setup an IMAP server so that you can login with Proton Mail. Shouldn’t be much of a hassle to set up.
Install Instructions
a proton mail bulk email deleter would be awesome
