[SOLVED] Discord module limitations
In short there are a few limitations I noticed for the Discord specific module while purging. The app cannot handle a purge that goes past a certain amount. I tried purging a DM chat that had about 73k messages and after a certain point the app seems to fail especially when it’s minimized.
  1. Essentially either the entire GUI will freeze or it will go black and also freeze. It might unstick but more often than not nothing happens. I’ve left it on overnight into next day and come back to it pure black. It also sometimes will be using a lot of RAM before it gets to that point, I think I saw it using 7 GB of it in Task Manager and I’m not sure why other than that it’s keeping all the messages it deleted in memory for some reason? Only reason I can think of. Tl;dr cannot handle massive amounts of DM purging without failing at some point.
  2. People who I think have the account blocked on Discord don’t show up in the DM list even though it has DMs with that person. The app seems unable to index these people when the account should still be able to access those DMs to delete. Tl;dr cannot access and delete DMs with people who are blocked and vice versa.
Hey Pacer, thanks for your feedback!
Were you using the ‘import data package’ feature for your deletion? For a job of that size we would strongly encourage you do.
  • Request your data here
  • Upload the file in app using “Import Data Package” (Easy) or “Delete from file” (Advanced)
Easy Mode:
Advanced Mode:
Re: Blocked Users - can you see your DMs with these people inside the Discord app “direct messages” section? If the DM is ‘closed’ you may not be able to find it (and Redact may struggle to load it). If you search for the user in the Discord DMs, and open your conversation with them, it should be added back to the list - in Discord, and Redact (probably after a refresh).
Give the above a try if you haven’t yet, it could clear up the issues. If you’ve tried these steps already, please get in touch with us directly via email/opening a ticket in discord & we’ll investigate and help out!
